2023-08-18 09:15 PM
Hello.
I want to use NUCLEO-G491RE with MCSDK6.1.2. However, NUCLEO-G491RE does not exist in the list of "Control" of MCSDK. If I have a NUCLEO-G491RE JSON file, can I import it? Where can I get the JSON file?
Thank you.
2023-08-21 08:45 AM
Hello @Takano ,
unfortunately this board is not currently supported by the MCSDK. You can add your board by clicking on this button:Documentation will be available very soon to help you describe your board.
In the meantime you can try to help yourself with the description of the other boards.
2023-08-21 08:45 AM
Hello @Takano ,
2023-08-21 06:34 PM
Hello Zied b.
I see. It means that there is no NUCLEO-G491RE JSON file anywhere now.I will try to make it as you told me.
Thank you.
