Can I use NUCLEO-G491RE with MCSDK6.1.2?
Takano
Hello.
I want to use NUCLEO-G491RE with MCSDK6.1.2. However, NUCLEO-G491RE does not exist in the list of "Control" of MCSDK. If I have a NUCLEO-G491RE JSON file, can I import it? Where can I get the JSON file?
Thank you.
Zied b.
Hello @Takano ,
unfortunately this board is not currently supported by the MCSDK. You can add your board by clicking on this button:add_board.PNGDocumentation will be available very soon to help you describe your board.
In the meantime you can try to help yourself with the description of the other boards.
If you agree with my answer, please accept it by clicking on "Accept as solution".
Zied b.
Hello @Takano ,
Takano
Hello Zied b.
I see. It means that there is no NUCLEO-G491RE JSON file anywhere now.I will try to make it as you told me.
Thank you.
