2020-07-09 01:24 AM
Hi, I'm trying to drive bldc motors for multicopter. So I sent PWM signal to esc using timer on my board. It works on SimonK firmware but BLheli does not work. I want to use BLheli firmware... How can I fix it? I think its protocol is Oneshot42
2020-09-14 01:24 AM
Dear Jbaek.1
Do you have still this problem to solve?
Best regards
Laurent Ca...
2020-09-15 10:29 PM
I solved this problem. I've changed the ESC....
2020-10-06 05:49 AM
And you have changed for... ?
