B-G431B position control doesn't achieve maximum speed
msingh08
Hi all,
I have profiled the motor using the motor profiler V5.4.8 where the motor was able to achieve 4500RPM, and then created a position control project CMWB V6.2.1. the motor is using 4096CPT incremental encoders as a primary feedback source. With this project I am only able to achieve maximum speeds of 700RPM and nothing more. Can anyone explain why that would be? I am aware that motor pilot can be used to plot graphs and I have been using that to display the current motor position however I'd like to know if it is possible to plot the target position as well?
  * @file    drive_parameters.h
  * @author  Motor Control SDK Team, ST Microelectronics
  * @brief   This file contains the parameters needed for the Motor Control SDK
  *          in order to configure a motor drive.
  * @attention
  * <h2><center>&copy; Copyright (c) 2023 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under Ultimate Liberty license
  * SLA0044, the "License"; You may not use this file except in compliance with
  * the License. You may obtain a copy of the License at:
  *                             www.st.com/SLA0044
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef DRIVE_PARAMETERS_H
#define DRIVE_PARAMETERS_H
 *** Motor Parameters ***
/******** MAIN AND AUXILIARY SPEED/POSITION SENSOR(S) SETTINGS SECTION ********/
/*** Speed measurement settings ***/
#define MAX_APPLICATION_SPEED_RPM       4596 /*!< rpm, mechanical */
#define MIN_APPLICATION_SPEED_RPM       0 /*!< rpm, mechanical,
                                                           absolute value */
#define M1_SS_MEAS_ERRORS_BEFORE_FAULTS 3 /*!< Number of speed
                                                             measurement errors before
                                                             main sensor goes in fault */
/*** Encoder **********************/
#define ENC_AVERAGING_FIFO_DEPTH        16 /*!< depth of the FIFO used to
                                                              average mechanical speed in
                                                              0.1Hz resolution */
/* USER CODE BEGIN angle reconstruction M1 */
#define REV_PARK_ANGLE_COMPENSATION_FACTOR 0
/* USER CODE END angle reconstruction M1 */
/**************************    DRIVE SETTINGS SECTION   **********************/
/* PWM generation and current reading */
#define PWM_FREQUENCY   10000
#define PWM_FREQ_SCALING 1
#define LOW_SIDE_SIGNALS_ENABLING        LS_PWM_TIMER
#define SW_DEADTIME_NS                   750 /*!< Dead-time to be inserted
                                                           by FW, only if low side
                                                           signals are enabled */
/* Torque and flux regulation loops */
#define REGULATION_EXECUTION_RATE     1    /*!< FOC execution rate in
                                                           number of PWM cycles */
#define ISR_FREQUENCY_HZ (PWM_FREQUENCY/REGULATION_EXECUTION_RATE) /*!< @brief FOC execution rate in
                                                           Hz */
/* Gains values for torque and flux control loops */
#define PID_TORQUE_KP_DEFAULT         100
#define PID_TORQUE_KI_DEFAULT         5
#define PID_TORQUE_KD_DEFAULT         100
#define PID_FLUX_KP_DEFAULT           200
#define PID_FLUX_KI_DEFAULT           5
#define PID_FLUX_KD_DEFAULT           100
/* Torque/Flux control loop gains dividers*/
#define TF_KPDIV                      126
#define TF_KIDIV                      16384
#define TF_KDDIV                      8192
#define TF_KPDIV_LOG                  LOG2((126))
#define TF_KIDIV_LOG                  LOG2((16384))
#define TF_KDDIV_LOG                  LOG2((8192))
#define TFDIFFERENTIAL_TERM_ENABLING  DISABLE
#define POSITION_LOOP_FREQUENCY_HZ    ( uint16_t )2000 /*!<Execution rate of position control regulation loop (Hz) */
#define PID_SPEED_KP_DEFAULT          10000/(SPEED_UNIT/10) /* Workbench compute the gain for 01Hz unit*/
#define PID_SPEED_KI_DEFAULT          100/(SPEED_UNIT/10) /* Workbench compute the gain for 01Hz unit*/
#define PID_SPEED_KD_DEFAULT          200/(SPEED_UNIT/10) /* Workbench compute the gain for 01Hz unit*/
/* Speed PID parameter dividers */
#define SP_KPDIV                      32
#define SP_KIDIV                      1024
#define SP_KDDIV                      16
#define SP_KPDIV_LOG                  LOG2((32))
#define SP_KIDIV_LOG                  LOG2((1024))
#define SP_KDDIV_LOG                  LOG2((16))
/* USER CODE BEGIN PID_SPEED_INTEGRAL_INIT_DIV */
#define PID_SPEED_INTEGRAL_INIT_DIV 1 /*  */
/* USER CODE END PID_SPEED_INTEGRAL_INIT_DIV */
#define SPD_DIFFERENTIAL_TERM_ENABLING DISABLE
#define IQMAX_A                          1
/* Default settings */
#define DEFAULT_CONTROL_MODE           MCM_POSITION_MODE //MCM_SPEED_MODE
#define DEFAULT_TARGET_SPEED_RPM       0.1
#define DEFAULT_TARGET_SPEED_UNIT      (DEFAULT_TARGET_SPEED_RPM*SPEED_UNIT/_001HZ)
#define DEFAULT_TORQUE_COMPONENT_A       0
#define DEFAULT_FLUX_COMPONENT_A         0
#define PID_POSITION_KP_GAIN			30000
#define PID_POSITION_KI_GAIN			1000
#define PID_POSITION_KD_GAIN			22000
#define PID_POSITION_KPDIV				128
#define PID_POSITION_KIDIV				32768
#define PID_POSITION_KDDIV				512
#define PID_POSITION_KPDIV_LOG			LOG2((128))
#define PID_POSITION_KIDIV_LOG			LOG2((32768))
#define PID_POSITION_KDDIV_LOG			LOG2((512))
#define PID_POSITION_ANGLE_STEP			0.01
#define PID_POSITION_MOV_DURATION		30.0
/**************************    FIRMWARE PROTECTIONS SECTION   *****************/
#define OV_VOLTAGE_THRESHOLD_V          28 /*!< Over-voltage
                                                         threshold */
#define UD_VOLTAGE_THRESHOLD_V          8 /*!< Under-voltage
                                                          threshold */
#ifdef NOT_IMPLEMENTED
#define ON_OVER_VOLTAGE                 TURN_OFF_PWM /*!< TURN_OFF_PWM,
                                                         TURN_ON_R_BRAKE or
                                                         TURN_ON_LOW_SIDES */
#endif /* NOT_IMPLEMENTED */
#define OV_TEMPERATURE_THRESHOLD_C      70 /*!< Celsius degrees */
#define OV_TEMPERATURE_HYSTERESIS_C     10 /*!< Celsius degrees */
#define HW_OV_CURRENT_PROT_BYPASS       DISABLE /*!< In case ON_OVER_VOLTAGE
                                                          is set to TURN_ON_LOW_SIDES
                                                          this feature may be used to
                                                          bypass HW over-current
                                                          protection (if supported by
                                                          power stage) */
#define OVP_INVERTINGINPUT_MODE         INT_MODE
#define OVP_INVERTINGINPUT_MODE2        INT_MODE
#define OVP_SELECTION                   COMP_Selection_COMP1
#define OVP_SELECTION2                  COMP_Selection_COMP1
/******************************   START-UP PARAMETERS   **********************/
/* Encoder alignment */
#define M1_ALIGNMENT_DURATION              700 /*!< milliseconds */
#define M1_ALIGNMENT_ANGLE_DEG             0 /*!< degrees [0...359] */
#define FINAL_I_ALIGNMENT_A               1 /*!< s16A */
// With ALIGNMENT_ANGLE_DEG equal to 90 degrees final alignment
// phase current = (FINAL_I_ALIGNMENT * 1.65/ Av)/(32767 * Rshunt)
// being Av the voltage gain between Rshunt and A/D input
#define TRANSITION_DURATION            25  /* Switch over duration, ms */
/******************************   BUS VOLTAGE Motor 1  **********************/
#define  M1_VBUS_SAMPLING_TIME  LL_ADC_SAMPLING_CYCLE(47)
/******************************   Temperature sensing Motor 1  **********************/
#define  M1_TEMP_SAMPLING_TIME  LL_ADC_SAMPLING_CYCLE(47)
/******************************   Current sensing Motor 1   **********************/
#define ADC_SAMPLING_CYCLES (6 + SAMPLING_CYCLE_CORRECTION)
/******************************   ADDITIONAL FEATURES   **********************/
/*** On the fly start-up ***/
 *** Control Parameters ***
/* ##@@_USER_CODE_START_##@@ */
/* ##@@_USER_CODE_END_##@@ */
#endif /*DRIVE_PARAMETERS_H*/
/******************* (C) COPYRIGHT 2023 STMicroelectronics *****END OF FILE****/
I have attached the code drive_parameters.h file that I am currently using
0 REPLIES 0
