2023-12-06 04:13 PM
2023-12-07 01:09 AM - edited 2023-12-07 01:10 AM
Hello sgordon777,
For every motor not available on the database, you must run the MotorProfiler tool, you can follow its startup guide on our wiki. Don't forget to save your motor configuration at the end of the profiling it order to create a new project using your motors.
Via Workbench, you can create a 6-STEP project by clicking on : New Project -> General Info tab -> 6-Step
Hello sgordon777,
2023-12-07 12:46 PM
Ok, figured out how to run the profiling, and the 6-step, I have some followup but I'll make a new psot. Thanks
