B-G431B-ESC1 as DC motor driver
Options
2020-03-30 09:30 AM
Hi.
I have been exploring the options on how to use the B-G431B-ESC1 board to drive a DC motor and so far I have also succeeded in doing so manually by reflashing the firmware with a custom one.
Unfortunately I am struggling with getting the current measurements right, since the PWM output and the chosen idle state of the MOSFETs seems to greatly affect the readings.
- All in all I would like some advice on when to sample the currents for DC motor driving?
- Any suggestions on how to sync the sampling with the PWM? I have tried both syncing it with the PWM timer, offsetting it with a specific non-output CC channel and then storing it through DMA. But I don't seem to get consistent results no matter where on the PWM cycle that I tend to sample.
- If there is any way to use the X-CUBE-MCSDK to drive a DC motor with the B-G431B-ESC1 board?
Looking forward to your advice.
Thank you in advance.
Best regards
Thomas Jespersen
Labels:
1 REPLY 1
Options
2021-06-27 10:14 PM
Adding of STM32 Motor Control topic.
Best regards.
