2021-02-23 01:23 AM
Hello everyone, I'm using the evaluation board of the motor driver POWERSTEP01 with a nucleo board NUCLEO-F401-RE. As the powerstep01 works by writing in regsitres via SPI, I would like to know if there are one or more libraries that allow the functions to be used directly in my program ?
Thank for your help
2021-02-23 04:36 AM
Did you already check the software package X-CUBE-SPN3, which also contains a driver in Drivers\BSP\Components\powerSTEP01?
/Peter
2021-02-23 04:36 AM
/Peter
2021-02-23 06:27 AM
Good luck!
/Peter
2021-02-23 06:44 AM
Thank for your help !
2021-02-23 06:47 AM
You're welcome, the community will always be happy to support you.
