zephyr support on NUCLEO_F439ZI board
Itachi
I am using zephyr rtos for my application. I am running basic Blinky example on ST boards. I am able to build and flash that examples on nucleo_h743zi board. however same example am trying to run on nucleo_f439zi board. Here am getting "Invalid Board" error.
CMake Error at D:/zephyrproject/zephyr/cmake/modules/boards.cmake:154 (message):
  Invalid BOARD; see above.
This error message am getting. above this msg we have list of supported board , i didn't find the nucleo_f439zi board in the list . so am bit confused do we have zephyr support on that particular board. or am I missing something. Kindly help me to solve this out.
Note-
I am using windows system and west tool to build and flash code.
Erwan Gouriou
Nucleo F439ZI is not yet supported in Zephyr RTOS.
You can find the list of bards available here:
https://docs.zephyrproject.org/latest/boards/arm/index.html
You should at least recommend NUCLEO-F429ZI:
https://docs.zephyrproject.org/latest/boards/arm/nucleo_f429zi/doc/index.html
The only difference is a crypto/hash peripheral not being available.
