X-CUBE-IOTA v1.2.0 precompiled version doesn't work
Kevin(Dr.Electron)
I tried to update my project to version 1.2.0 and it didn't work. I now also found out that the precompiled version for the stm32f4 doesn't work. Also if I compile it by myself it doesn't work.
I get a valid ip with dhcp but the ip gets released immediately. Is this an error on my side? It did work with previous versions. But as a lot of network stuff has changed in 1.2, I'm not sure if there may be a bug. Let me know if i can help with further infos
Andrea Palmieri
Hello Kevin,
We're pleased to inform you that the new release of X-CUBE-IOTA1 V1.3.0 fixes the issue you have raised. It was due to a misalignment with the LwIP library.
Please, find the package on st.com
Let us know if it works on your side.
Kind regards
3 REPLIES 3
Andrea Palmieri
Hi Kevin,
Thanks for raising this issue. We're currently looking into this. Thanks for your patience.
Andrea Palmieri
Hello Kevin,
Kind regards
Kevin(Dr.Electron)
Thanks, all works fine now
