Using stm32f767zi to save data from lidar to usb drive
Twistereek
As in the title, i need to take the data coming from velodyne lidar vlp-16 through ethernet cable and save it to some usb pendrive or hard drive. I am using stm32f767zi. Data will be coming at about 20Mbit/s and i do not need to do anything with it, just save it. However, i am having trouble finding anything similar to this, and as i am a begginer i have no idea how to really start doing this, so i would very much apprecieate any help on the subject.
Probably be far easier building this with RPi in Linux..
Or similar credit card / smaller SBC
FBL
Hello @Twistereek
You can start with STM32Cube\Repository\STM32Cube_FW_F7_V1.17.1\Projects\STM32F767ZI-Nucleo\Applications\LwIP\LwIP_HTTP_Server_Netconn_RTOS software package as an example of HTTP server application based on LwIP TCP/IP stack.
Best regards,
FBL
LCE
Principal II
Warning: Ethernet, USB and a file system in-between is nothing you can solve with a few clicks in CubeMX.
Even a pro will need a few weeks or even months for this, so expect to have a hard year ahead.
But not to discourage you, you will learn a lot! ;)
