USB Error while transmitting UART
Chuev.Vladimir
Posted on November 08, 2017 at 12:38
I'm using STM32F401CBUX
I have a USB HID that works well
But when I call HAL_UART_Transmit_IT/HAL_UART_Transmit_DMA/HAL_UART_Transmit, there's a USB cliff on the host side
What could be the matter? I don't understand anything
#usb-hid #custom-hid #uart
4 REPLIES 4
Posted on November 08, 2017 at 18:03
Tx on PA9 and VBUS sensing in USB on?
Posted on November 09, 2017 at 08:56
Yes.
Can I fix the problem without changing the board?
Why is this happening? Will the same problem be with the usual GPIO?
Posted on November 09, 2017 at 09:53
From RM:
The VBUS pin can be freed by disabling the V BUS sensing option. This is done by setting the
NOVBUSSENS bit in the OTG_FS_GCCFG register. In this case the V BUS is considered
internally to be always at V BUS valid level (5 V).
There probably will be a ♯ define or a configuration setting in the library you are using to achieve this. Please report back with your findings.
Posted on November 13, 2017 at 12:14
Thank you! This helped
