UART Serial Monitor using VS Code, Linux, and ST-Link
‎2025-01-13 10:17 AM - edited ‎2025-01-13 10:18 AM
I have an older STM32 Nucleo-F746ZG and I want to try and send some serial over the ST-Link. I am in Ubuntu with VS Code. I have successfully built the project and it appears to be running in debug mode. However when I try to connect and read the serial output via Screen, Putty or even the Serial Monitor extension nothing is showing up on the serial port. I have found the ST-Link is at /dev/ttyACM0 and I have added my user to the dialout group, but nothing shows up.
I am using UART2 in Asynchronous mode, added interrupt and using VS Code in debug mode. I suspect that this is OS related, but wanted to know if anyone had any suggestions on where to look.
I have done other projects with STM32-Nucleo and VS Code so I believe this is a simple error on my part related to the ST-Link usb in Linux.
Doug
- Labels:
STM32F7 Series
UART-USART
‎2025-01-13 11:06 AM
right, seems to be on usart3 :
‎2025-01-14 12:07 AM
@hdferguson3 wrote:The tutorial was a YouTube video I am embarrassed to say.
You could leave a comment on the tutorial in question.
Nothing wrong with YouTube per se - ST themselves have loads of tutorials on YouTube
https://www.youtube.com/@stmicroelectronics
- « Previous
- 1
- 2
- Next »
