Trying to compile Ultrasound FFT from SW_Source using QT and getting an error message that libhs_datalog.dll is corrupt.
‎2023-03-06 1:30 AM
‎2023-11-17 4:42 AM
This's my screenshot for your reference. Please ST kindly support this. Thanks in advance.
‎2023-11-24 6:17 PM
Hi SPRAD.1,
Any progress to resolve this issue?
‎2023-11-29 3:39 AM
I'm sorry, but the maintenance release planned for the last quarter has been moved to the end of the year.
Best regards
‎2023-11-29 3:48 AM
which year exactly ?
because end of 2023 is now close.
‎2023-11-29 3:55 AM
We're testing now the package. If no issues will come up in the next days, the package should be online in wk51 '23, else in wk3 '24.
Best regards
‎2023-11-29 4:17 AM
The wk51'23 is making my project in risk but better than nothing.
If it's wk3'24, my project will be completely dead. So, please, please provide it wk51 and early is even better. Thank a lot in advance.
‎2023-11-30 1:38 AM
The DLL included in the UltrasoundFFT project within X-CUBE-MEMSMIC1 is not corrupted as stated in the compiler message, it is simply meant to be compiled with GCC and not MSVC.
When you load the project, if you select MinGW 32-bit as a compiler, you are able to compile everything without any issue.
‎2023-12-01 1:53 AM
@Davide G Yes, it works. Thank you, Thank you so much for help.
- « Previous
- 1
- 2
- Next »
