STM32L4R5xx SVD file error
2019-01-30 2:46 AM
I try to see value in DMA and DMAMUX registers, but I don't find it in svd files. Although, there is a description for DMA, but it is not correct as according to the RM there is no register DMA_CSEL in DMA, however, it is described in the SVD file.
the module DMAMUX with register description is completely missing.
- Labels:
DMA
STM32L4 series
SVD
2019-02-01 12:45 AM
Hello @chemax ,
We raised this issue internally for check and fix.
Thank you for your contribution.
Kind Regards,
Imen
Imen
2019-02-01 1:41 AM
Thank you too.
I assume that the error has crept in for the whole family of L4+. I opened the following files: stm32l4r5.svd, stm32l4r7.svd, stm32l4r9.svd and did a search for the word "DMAMUX".
Kind Regards,
Max
2019-02-28 11:44 PM
I understand that you have a lot of work, but still I would like to know:
A month has passed since my question about the content of errors in the SVD files of the STM32L4+ series. What is the progress on this issue?
We also found discrepancies in the description of the register of timers in the SVD and the reference's manual.
There is also a fear that the file with the register description stm32l4xx.h may contain errors, since it is generated on the basis of the SVD files.
Best regards,
Maxim
