STM32H743 Example Issue MDMA Repeat Block Rotation Example
2021-09-24 1:52 AM
In this example its mentioned that it can rotate RGB565 image by 90 degree using MDMA. i cant find the code for 90 degree rotation so its not possible or what exactly??
@Imen DAHMEN
2021-09-24 3:28 AM
Hello @Community member ,
You are right, the rotation value is 180° (not 90°).
Indeed, the 90 deg transformation is not a supported feature by the MDMA.
So, the readme file will be updated to correct the rotation value from 90° to 180° of the MDMA_RepeatBlock_Rotation application to reflect the behavior of the example.
(Internal ticket 107449: This is an internal tracking number and is not accessible or usable by customers)
Thanks for your contribution.
Imen
Imen
2021-09-24 3:28 AM
Imen
Imen
2021-09-24 3:59 AM
@Imen DAHMEN
Ok, Can the MDMA combined with DMA2D rotate image 90 degree?
2021-09-24 4:03 AM
MDMA is not able to provide 90 deg rotation as it is a classic linear DMA (can not preform transformation).
The only 180 deg and mirror effect are possible with this linear MDMA (using multi block and address increment/decrement feature).
Hope this answer you question.
Imen
Imen
2021-09-24 4:18 AM
@Imen DAHMEN
If i used MDMA to decrement the destination address and then the Graphic engine DMA2D to transform lines into columns. will this work?
