2019-03-25 7:27 PM
There is a packing mode check in Drivers/STM32H7xx_HAL_Driver/Src/stm32h7xx_hal_spi.c, function HAL_SPI_Transmit_DMA
around line 1464, that is referencing RX side DMA handle:
1464 /* Packing mode management is enabled by the DMA settings */
1465 if (((hspi->Init.DataSize > SPI_DATASIZE_16BIT) && (hspi->hdmarx->Init.MemDataAlignment != DMA_MDATAALIGN_WORD)) || \
1466 ((hspi->Init.DataSize > SPI_DATASIZE_8BIT) && ((hspi->hdmarx->Init.MemDataAlignment != DMA_MDATAALIGN_HALFWORD) && \
1467 (hspi->hdmarx->Init.MemDataAlignmen t != DMA_MDATAALIGN_WORD))))
1468 {
1469 /* Restriction the DMA data received is not allowed in this mode */
1470 errorcode = HAL_ERROR;
1471 __HAL_UNLOCK(hspi);
1472 return errorcode;
1473 }
I believe all references to hdmarx should be hdmatx in this context. The hdmarx may not even be initialized properly.
Thoughts?
2019-03-26 7:43 AM
Hello @Yoichi Shinoda ,
We have already passed this issue along to our development team for fix in the coming release of STM32CubeH7.
Thanks for your contribution.
Best Regards,
Imen
2019-03-26 7:43 AM
Best Regards,
Imen
