2025-07-02 4:33 AM - last edited on 2025-07-02 5:29 AM by mƎALLEm
2025-07-03 8:20 AM
That's essential information to get the task done!
2025-07-03 9:14 AM
if you want to help me please help otherwise your choice go and sit your table.
2025-07-03 10:02 AM - edited 2025-07-04 1:17 AM
Attached below is a working Ethernet project using LwIP and FreeRTOS v1 on the STM32H753ZITx. You can use the Compare Projects tool in STM32CubeMX to compare this working project with your configuration, identify differences, and update your settings accordingly. Similarly, you can compare the rest of the project files to spot any discrepancies.
Although this example is a UDP echo server, you can certainly modify it to fit your specific needs. For a detailed walkthrough of the steps, please refer to the article linked below.
2025-07-07 2:10 AM
Hello @rockey1,
Do you have any updates regarding your issue? Were you able to resolve it? If so, please remember to mark the response that helped you as a solution by clicking Accept As Solution. This will help other users benefit from the information as well.
Best regards,
