2021-07-18 6:27 AM
This is nur. I need your help. I am working on STM32F769 phy chip , RMII interface. Once I apply power the stm chip then Ethernet cable clicked , there is no connection. if Ethernet cable does not click into place before power is applied to the chip, there is no connection. Why?
Thanks.
2021-07-18 11:45 AM
Because the HAL/Cube firmware code is a junk
2021-07-18 12:11 PM
Thanks Piranha for your reply. I took a look at the link you sent. The bug was not fixed, right ?
