2022-04-20 06:01 AM
the LAN8720A has not the Tx_clk and Rx_Clk signals. Does the STM32F765 supports this configuration supposed I use the LAN8720A in slave mode routing to it the 25MHZ clock generated from the MCU from a ClockOut pin?
Thank you.
2023-02-09 11:42 PM
In fact you couldn't use MII ethernet with the LAN8720A only RMII is available on it.
