STM32F7 lwIP Ethernet [FreeRTOS] - TxPktSemaphore not given
leoneln
I'm developing a device that works as a modbus slave over TCP/IP. For this application I'm using FreeRTOS with CMSIS-v1 and LwIP. The problem occurs sometimes when I disconnect the master (a PC with modbus poll), then the code stucks waiting for a semaphore (TxPktSemaphore) inside the function low_level_output() on ethernetif.c
Here is the part of the code where the ejecution keeps waiting forever a semaphore (line 8).
TxConfig.Length = p->tot_len;
  TxConfig.TxBuffer = Txbuffer;
  TxConfig.pData = p;
  pbuf_ref(p);
  HAL_ETH_Transmit_IT(&heth, &TxConfig);
  while(osSemaphoreWait(TxPktSemaphore, TIME_WAITING_FOR_INPUT)!=osOK)
  HAL_ETH_ReleaseTxPacket(&heth);
  return errval;
In addition, I attach a wireshark capture when the master (10.8.51.2) request the end of the connection and the problem doesn´t occur:
But when the problem occasionally occurs, there is a RST:
0693W00000WL8B7QAL.pngPlease consider in both captures that I have more than one connection at the same time between master and slave, that's the reason there is activity after the desconnection (belongs to other ports
Thanks in advance.
6 REPLIES 6
EOzde.1
What version of FreeRTOS you are using V1 or V2 ?
Semer CHERNI
Hello @leoneln​
First let me thank you for posting.
You need to identify the exact task holding the semaphore causing the described behavior.
STM32CubeIDE offer many feature which could help you have a clear view on the execution of the tasks when using FreeRtos.
I advice you to check the UM2609 - Rev 7 chapter 6.2 and 6.3.
I will be waiting for your feedback as it is very important to improve the tool's features.
Kind regards,
Semer.
Hi, thanks for replying.
I'm using CMSIS-v1 and FreeRTOS Kernel V10.2.1.
I show my FreeRTOS config below:
#define configENABLE_FPU                         0
#define configENABLE_MPU                         0
#define configUSE_PREEMPTION                     1
#define configSUPPORT_STATIC_ALLOCATION          1
#define configSUPPORT_DYNAMIC_ALLOCATION         1
#define configUSE_IDLE_HOOK                      0
#define configUSE_TICK_HOOK                      0
#define configCPU_CLOCK_HZ                       ( SystemCoreClock )
#define configTICK_RATE_HZ                       ((TickType_t)1000)
#define configMAX_PRIORITIES                     ( 7 )
#define configMINIMAL_STACK_SIZE                 ((uint16_t)128)
#define configTOTAL_HEAP_SIZE                    ((size_t)15360)
#define configMAX_TASK_NAME_LEN                  ( 16 )
#define configUSE_16_BIT_TICKS                   0
#define configUSE_MUTEXES                        1
#define configQUEUE_REGISTRY_SIZE                8
#define configUSE_PORT_OPTIMISED_TASK_SELECTION  1
/* Defaults to size_t for backward compatibility, but can be changed
   if lengths will always be less than the number of bytes in a size_t. */
#define configMESSAGE_BUFFER_LENGTH_TYPE         size_t
/* Co-routine definitions. */
#define configUSE_CO_ROUTINES                    0
#define configMAX_CO_ROUTINE_PRIORITIES          ( 2 )
/* The following flag must be enabled only when using newlib */
#define configUSE_NEWLIB_REENTRANT          1
/* Set the following definitions to 1 to include the API function, or zero
to exclude the API function. */
#define INCLUDE_vTaskPrioritySet             1
#define INCLUDE_uxTaskPriorityGet            1
#define INCLUDE_vTaskDelete                  1
#define INCLUDE_vTaskCleanUpResources        0
#define INCLUDE_vTaskSuspend                 1
#define INCLUDE_vTaskDelayUntil              0
#define INCLUDE_vTaskDelay                   1
#define INCLUDE_xTaskGetSchedulerState       1
leoneln
[This answer need to be deleted]
I did what you suggest and here is the capture:
There is a callback interruption that releases the semaphore:
void HAL_ETH_TxCpltCallback(ETH_HandleTypeDef *handlerEth)
  osSemaphoreRelease(TxPktSemaphore);
The interrupt never seems to happen and of course this blocks execution.
In addition, I reached to the function vListInsert() in list.c [FreeRTOS]. There is a "for" sentence and the exceution keeps there forever. Inside the function is a note:
/* *** NOTE ***********************************************************
		If you find your application is crashing here then likely causes are
		listed below.  In addition see https://www.freertos.org/FAQHelp.html for
		more tips, and ensure configASSERT() is defined!
		https://www.freertos.org/a00110.html#configASSERT
			1) Stack overflow -
			   see https://www.freertos.org/Stacks-and-stack-overflow-checking.html
			2) Incorrect interrupt priority assignment, especially on Cortex-M
			   parts where numerically high priority values denote low actual
			   interrupt priorities, which can seem counter intuitive.  See
			   https://www.freertos.org/RTOS-Cortex-M3-M4.html and the definition
			   of configMAX_SYSCALL_INTERRUPT_PRIORITY on
			3) Calling an API function from within a critical section or when
			   the scheduler is suspended, or calling an API function that does
			   not end in "FromISR" from an interrupt.
			4) Using a queue or semaphore before it has been initialised or
			   before the scheduler has been started (are interrupts firing
			   before vTaskStartScheduler() has been called?).
