2019-03-14 03:38 AM
According to the reference manual (RM0390) main PLL in F446 has a third output, defined by PLLR, where previous version (F429 et al.) had reserved bits (with same reset state). But in latest (1.2) revision of F446 SVD file that field is missing, and PLLR output is missing as source of SYSCLK.
2020-07-29 08:06 AM
Hi mai119lb,
I did attach the latest version for F446 SVD file we have today (v1.4).
I hope it has the fix. If not we will try to fix in upcoming version.
Don't hesitate to share your feedbacks!
Imen
