2022-10-06 02:08 AM
Hello everyone
I am trying to implement a simple soundcard from using STM32F407G-DISC1 board.
It utilizes STM32F407. I am using CubeIDE version 1.10.1
I configured the USB to be Full-speed Device Only. And I configured the middleware as Audio class.
I set the the heap size at 0x4000, and stack size at 0x2000.
When I connect it via the USB, Windows surely recognizes it as "Speakers".
I know that when the microcontroller receives Audio data, I should have access to the samples in the "AUDIO_AudioCmd_FS" function.
The problem is that, when I send Audio data to the microcontroller, the AUDIO_AudioCmd_FS function gets called only once, and it does not get called again.
No matter how many times I resend Audio data from the PC to the microcontroller, the AUDIO_AudioCmd_FS function does not get called again.
Can anyone please help me with this issue?
2022-10-07 02:44 AM
My problem is solved!
I want to point out 2 things:
I copied the following files into my project:
/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pcd.c
/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_hal_pcd_ex.c
/Drivers/STM32F4xx_HAL_Driver/Src/stm32f4xx_ll_usb.c
/Middlewares/ST/STM32_USB_Device_Library/Class/AUDIO/Src/usbd_audio.c
/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_core.c
/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ctlreq.c
/Middlewares/ST/STM32_USB_Device_Library/Core/Src/usbd_ioreq.c
/USB_DEVICE/App/usb_device.c
/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_pcd.h
/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_hal_pcd_ex.h
/Drivers/STM32F4xx_HAL_Driver/Inc/stm32f4xx_ll_usb.h
/Middlewares/ST/STM32_USB_Device_Library/Class/AUDIO/Inc/usbd_audio.h
/Middlewares/ST/STM32_USB_Device_Library/Core/Inc/usbd_core.h
/Middlewares/ST/STM32_USB_Device_Library/Core/Inc/usbd_ctlreq.h
/Middlewares/ST/STM32_USB_Device_Library/Core/Inc/usbd_def.h
/Middlewares/ST/STM32_USB_Device_Library/Core/Inc/usbd_ioreq.h
Now it works.. I think
2022-10-07 02:44 AM
2022-10-20 02:43 AM
Hi @Sami
Really glad to know you overcame this problem.
Please allow me to close this thread.
Thank you for your contribution and all the details you provided.
Imen
