STM32F207VC SDIO and Fatfs Problem
‎2016-07-11 2:27 AM
Hi All
I am Using STM32F207VC And Micro SD Card With SDIO Interface And Fatfs Library When I Debug And Trace Code, SDIO Routine Response This Error: /*!< Card is not V2.0 complient or card does not support the set voltage range */ What Is Mean? What Do I Do For debug This Error? #fatfs #sdio #sdio #stm32f207 #dma-config-for-sdio- Labels:
FatFS
SDIO-SDMMC
STM32F2 Series
‎2016-07-11 5:09 AM
Describe the specific card (make, model, capacity, etc) you are having problems with. Are other cards working? Is the interface wired correctly? What board is this?
Make sure the SDSTATUS_Tab has 64 elements. The error seems to suggest the card is non-responsive Test the code/card on known working hardware.Up vote any posts that you find helpful, it shows what's working..
‎2016-07-11 5:53 AM
hi clive And Tanks For Response
I Read AArticle
?About SDIO Interfacehttp://blog.frankvh.com/2011/09/04/stm32f2xx-sdio-sd-card-interface/
That Write About Hardware That must Use A Buffer For SDIO Voltage My Board Dont Have Any Buffer And Connect MicroSD Driectly To STM32F207VC Is There Any Issuse For This Problem?- Mark as New
‎2016-07-11 12:47 PM
I have my card detect with a pull-up, the socket grounds the pin.
You'd need to make sure you use external pull-ups on the data, and command pins, or configure them with pull-ups. This configuration works for an assortment of F2 and F4 boards.void SD_LowLevel_Init(void)
/* GPIOC and GPIOD Periph clock enable */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOD | SD_DETECT_GPIO_CLK, ENABLE);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_SDIO);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource9, GPIO_AF_SDIO);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_SDIO);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource11, GPIO_AF_SDIO);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource12, GPIO_AF_SDIO);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource2, GPIO_AF_SDIO);
/* Configure PC.08, PC.09, PC.10, PC.11 pins: D0, D1, D2, D3 pins */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_25MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Configure PD.02 CMD line */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_Init(GPIOD, &GPIO_InitStructure);
/* Configure PC.12 pin: CLK pin */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
/*!< Configure SD_SPI_DETECT_PIN pin: SD Card detect pin */
GPIO_InitStructure.GPIO_Pin = SD_DETECT_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_Init(SD_DETECT_GPIO_PORT, &GPIO_InitStructure);
/* Enable the SDIO APB2 Clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SDIO, ENABLE);
/* Enable the DMA2 Clock */
RCC_AHB1PeriphClockCmd(SD_SDIO_DMA_CLK, ENABLE);
The SDIO requires the PLL to be clocking to function.
A board running at 2.7 - 3.3V shouldn't require any voltage adjustment.
I'll assume no cards are working..
‎2016-07-11 11:32 PM
Hi Clive
That's Great And My ProblemSolved
! But I Have A New Problem With DMA Config Now! The DMA Flag Dos Not Set And Stay Reset I Think The SDIO Routine Not Configure Correctly Because I Ported STM32F10X SDIO Routine To My Project. I Attached SDIO Routine File. Please Help Me Tanks Very Very Much ________________ Attachments : sdio_sd.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Ja&d=%2Fa%2F0X0000000beG%2F39c6D4aF8Wj9_1u35QlaceV7JHtaLxmZ1mvfwqKxwtY&asPdf=falsesdio_sd.h : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0pu&d=%2Fa%2F0X0000000beF%2FqsvUs3V2GoY8g3teMhMYkgM1pSzr3poEZRMnCCLK_gs&asPdf=false- Mark as New
‎2016-07-13 2:31 AM
The DMA initialization structure needs to specify channel.
DMA Flags need to end in stream number, ie TCIF3.Up vote any posts that you find helpful, it shows what's working..
‎2016-07-16 1:43 AM
Hi Dear Clive
I Very Tried To Run This Project But SDIO Routine Run In This While Loop:while ((SD_DMAEndOfTransferStatus() == RESET) && (TransferEnd == 0) && (TransferError == SD_OK))
this Is My DMA Config In Project in SDIO.c File:
void SD_LowLevel_DMA_RxConfig(uint32_t *BufferDST, uint32_t BufferSize)
DMA_InitTypeDef DMA_InitStructure;
DMA_ClearFlag(DMA2_Stream3,DMA_FLAG_TCIF3 | DMA_FLAG_TEIF3 | DMA_FLAG_HTIF3 | DMA_FLAG_DMEIF3 | DMA_FLAG_FEIF3);
//DMA_ClearFlag(DMA2, SD_SDIO_DMA_FLAG_FEIF | SD_SDIO_DMA_FLAG_DMEIF | SD_SDIO_DMA_FLAG_TEIF | SD_SDIO_DMA_FLAG_HTIF | SD_SDIO_DMA_FLAG_TCIF);
/*!< DMA2 Channel4 disable */
//DMA_Cmd(DMA2_Channel4, DISABLE);
DMA_Cmd(DMA2_Stream3, DISABLE);
/*!< DMA2 Channel4 Config */
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SDIO_FIFO_ADDRESS;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)BufferDST;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = BufferSize / 4;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
//DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA2_Stream3, &DMA_InitStructure);
/*!< DMA2 Channel4 enable */
DMA_Cmd(DMA2_Stream3, ENABLE);
* @brief Configures the DMA2 Channel4 for SDIO Tx request.
* @param BufferSRC: pointer to the source buffer
* @param BufferSize: buffer size
* @retval None
void SD_LowLevel_DMA_TxConfig(uint32_t *BufferSRC, uint32_t BufferSize)
//DMA_ClearFlag(DMA2_FLAG_TC4 | DMA2_FLAG_TE4 | DMA2_FLAG_HT4 | DMA2_FLAG_GL4);
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)BufferSRC;
‎2016-07-16 7:52 AM
DMA_InitStructure.DMA_Channel = DMA_Channel_4; // Must specify a channel in the initialization structure
‎2016-07-16 8:44 AM
Tanks Clive
that's Right and Other Problem Was The DMA Must Be Enable Before Clear Flags I Corrects All Things And Now I Receive FR_NO_FILESYSTEM Response In f_open Function when I Trace And Debug Code : The Disk_read() Response SD_OK The check_fs() Response 2 => /* No FAT volume is found */- Mark as New
‎2016-07-19 7:05 AM
Is There Any Body For Ask My Question?
When I Debug Project I Receive FR_NO_FILESYSTEM Response In F_Open Function when Trace Project Routine The check_fs() Function Response ''2'' and Then Response FR_NO_FILESYSTEM /* No FAT volume is found */ Tanks All
