simple TCP and UDP examples for f4
‎2012-11-25 5:54 AM
#lwip #uip #tcp/ip-stack #describe-the-goal-not-the-step- Labels:
Ethernet
‎2012-11-25 6:04 AM
Just how simple are we talking about, done any networking or programming before? And for what board?
Here's a LwIP example from the download pageshttp://www.st.com/internet/com/SOFTWARE_RESOURCES/SW_COMPONENT/FIRMWARE/stm32f4x7_eth_lwip.zip
There are a bunch of other examples if you care to look.Up vote any posts that you find helpful, it shows what's working..
‎2012-11-25 6:12 AM
The LwIP is too complex
i use simple minimum library for send one pocket to direct linked PC & also receive it- Mark as New
‎2012-11-25 7:01 AM
Perhaps a commercial solution would be simpler and better documented.Up vote any posts that you find helpful, it shows what's working..
‎2012-11-25 7:20 AM
''The LwIP is too complex''
LwIP really is quite simple as IP stacks go!
Perhaps you should look at uIP - which is a minimalist stack for really small microcontrollers...A complex system designed from scratch never works and cannot be patched up to make it work.
‎2012-11-27 12:33 AM
I don’t need
IP STACK ,it’s obvious that if I need it, I will use LWIP.
I’m beginner in using Ethernet so I prefer the easiest
form of sample code which can send simple Ethernet frame to the computer through Ethernet and also receive the frame
from program such as WIRESHARK.It’s also able to send a frame to the F4.
So that as the first step in learning but not real use of it .
I like
a simple code like BLINKING LED for Ethernet do you remember it ?- Mark as New
‎2012-11-27 12:58 AM
But your question was ''simple TCP and UDP examples for f4''. Both TCP and UDP run on top of IP and therefore do require a (TCP/)IP stack. Maybe you need to ask a different question?
‎2012-11-27 4:11 AM
‎2012-11-27 6:21 AM
''i need send & receive simple Ethernet frame''
Why?
http://www.catb.org/~esr/faqs/smart-questions.html#goal
And what will you use to receive those frames...?A complex system designed from scratch never works and cannot be patched up to make it work.
‎2012-11-27 6:44 AM
For raw Ethernet frames (802.3), you might want to look at interfacing to the ETH driver :
STM32F2-F4_Demonstration_Builder_V1.0.1\Libraries\STM32F4x7_ETH_Driver\src\stm32f4x7_eth.cUp vote any posts that you find helpful, it shows what's working..
