stm32f107 ethernet tcp or udp
Posted on August 21, 2012 at 10:15
hi, i am using stm32f107vc.. for ethernet programming which one is good? TCP or UDP... i just use the ethernet communication for transferring sensor data..i am new to ethernet and stm32f107...i am using dp83848... i need some example codes... how to use tcp or udp in programming...
