Sending integer values through UART (STM32L0R8) (HAL drivers)
aniltirli
Posted on June 26, 2016 at 12:05
hi
i am trying to send integer values from my nucleo board to my pc by using UART, i.e. you can take that sensor values. The UART example ''UART_TwoBoards_ComPolling'' in the stm32Cube that uses HAL libraries, only sends strings.
data to send defined like this
uint8_t aTxBuffer[] = '' ANIL TIRLIOGLU'';
and function to send data is like this :
HAL_UART_Transmit(&UartHandle, (uint8_t*)aTxBuffer, TXBUFFERSIZE, 5000);
How can i send something like
uint8_t  TxBuffer = 111;
#stm32 #adc #hal #hal #c-learning #uart-ft-serial-communications
Posted on June 26, 2016 at 17:09
char aTxBuffer[16];
HAL_UART_Transmit(&UartHandle, (uint8_t*)aTxBuffer, sprintf(aTxBuffer, ''%d'', 111), 5000);
AKhot.1
Were you able to find how to send integers through uart?
