SD Card Not Working (FR_NOT_READY) on Cube IDE Version 1.12.0
2023-03-31 2:37 AM
Hi, I have STM32F413VHT6 board and trying to use FATFS and SDIO card slot, but f_mount returns FR_NOT_READY. i worked in 1 bit mode is working perfectly but SDIO in 4 bit mode f_mount return FR_NOT_READY.i am using below code for both 1 bit and 4 bit mode i am changing the clock divider value 4 to 10 and check clock divider in 96 also 4 bit is not working.
Any ideas what is the issue and how to solve this problem?
FatFS
SDIO-SDMMC
2023-04-24 4:25 AM
Hello @AA.27 ,
Is your project generated with STM32CubeMX?
If yes, could you please check that the workaround provided in this thread: SDCARD does not work (FR_NOT_READY) when migrating from FW_F4 V1.27.0 to newer FW_F4 V1.27.1.
Kaouthar
2023-03-31 2:52 AM
You describe a chip not a board.
Check wiring and trace length for socket.
You have pullups on data and command lines?
Debug at DISKIO/SDIO level.
2023-03-31 4:26 AM
i received this error
#define HAL_SD_ERROR_REQUEST_NOT_APPLICABLE SDMMC_ERROR_REQUEST_NOT_APPLICABLE /*!< Error when command request is not applicable */
i checked both pullup and no pullup and trace length of the socket also correct.
i am using NUCLEO-F413ZH board. In my SDIO card reader pullup resister available.
i am using 32GB micro SDHC card class 1.This is my SD card reader
2023-04-02 1:10 PM
Could it be related to this case?
STM32CubeMX 6.7.0 Breaks SD 4 Bits Wide Bus SDMMC on STM32L496xx STM32L4A6xx
2023-04-03 10:33 PM
I am getting the same error. what was your solution? thank you!
2023-04-24 4:25 AM
Hello @AA.27 ,
Kaouthar
