2023-10-27 1:06 AM
I would like to know how to recover acquisition data and save the data to an SD card. I have this configuration
I can compile and communicate with I2C to configure the SGTL5000 CODEC, I enabled DMA too. No errors for this moments.
Thank you for your helps.
2023-10-27 7:31 AM
I have this code below but I don't know how does it work ?
HAL_SAI_RegisterCallback(&hsai_BlockB1, HAL_SAI_TX_HALFCOMPLETE_CB_ID, HAL_SAI_TxHalfCpltCallback);
HAL_SAI_RegisterCallback(&hsai_BlockB1, HAL_SAI_TX_COMPLETE_CB_ID, HAL_SAI_TxCpltCallback);
fresult= HAL_SAI_Init(&hsai_BlockB1);
if (fresult != HAL_OK)
return HAL_ERROR;
fresult = HAL_SAI_Transmit_DMA(&hsai_BlockB1, (uint8_t *)playbuf , (sizeof(playbuf))/4);
Do you have a idea how to get the acquisition values ?
