osMemoryPoolDelete or osMemoryPoolFree ?
‎2023-02-08 03:19 PM
I have allocated memory pool for my doubly linked list using
osMemoryPoolNew
I want to be able to insert and delete nodes to the doubly linked list. My question is , When I am deleting the node I am unsure if I have to using osMemoryPoolDelete or osMemoryPoolFree.
I know I should be using FREERTOS vPortFree . But I am unsure in CMSIS context. Can anyone please clarify this .
‎2023-02-09 09:40 AM
osMemoryPoolNew and osMemoryPoolDelete is one function pair for an entire pool, and
osMemoryPoolAlloc and osMemoryPoolFree a pair for a memory block within a pool, like your nodes.
See https://arm-software.github.io/CMSIS_5/RTOS2/html/group__CMSIS__RTOS__PoolMgmt.html
Keep in mind, that there is no virtual addressing available, so heavy dynamic use of alloc and free may defragment the heap or, at least, have non-constant run-time.
hth
KnarfB
‎2023-02-09 10:29 AM
Thank you ! I have couple of follow up questions
So do I have to create a pool before I use osMemoryPoolAlloc and osMemoryPoolFree?
I am using heap_4.c . Do you think there will be still defragmentation problem ? Or what is the other way you might suggest ? Do I have to just goahead with Arrays than doubly linked list?
‎2023-02-10 12:50 AM
It all depends on your usage pattern. osMemoryPoolAlloc doesn't call heap malloc.
Check the implementation of memory pools in cmsis_os2.c. Note how AllocBlock walks a linear list to find a free block.
Pools are typically used for equally sized (larger) buffers. Say, if you move buffers of digitized audio around in queues, you want to move them "copy-free", which can be achieved with memory pool buffers and only pointers in the queues.
hth
KnarfB
‎2023-02-19 02:18 PM
The topic is about pools, not heaps, and pools cannot fragment.
It's the fragmentation, not the opposite one.
By the way, virtual memory solves the fragmentation of physical memory, but still cannot solve the fragmentation of a virtual address space for a particular process.
