Nx_Azure_IoT example adapted for our STM32U585QII6Q board . Every time STM32CubeMX regenerates the code, it deletes three files: nx_tcp_socket_driver_establish.c, nx_tcp_socket_driver_packet_receive.c and ...
JVica.1
I have adapted the Nx_Azure_IoT example for my board with an STM32U585QII6Q. My problem is that every time STM32CubeMX regenerates the code, it deletes three files that I added: nx_tcp_socket_driver_establish.c, nx_tcp_socket_driver_packet_receive.c and nx_udp_socket_driver_packet_receive.c. I have checked the NETXDUO settings in the example of the nx_udp_socket_driver_packet_receive.c board and those of my board and they are identical. Why does the original project include these files and mine doesn't?
4 REPLIES 4
Ghofrane GSOURI
Hello @JVica.1​
I tried to reproduce the same behavior you encountered but it works fine from my side.
To be able to push further the analysis could you please provide a minimal project which show the problem.
I'll be waiting for your feedback.
Thx.
Ghofrane
JVica.1
Hi Ghofrane, sorry for the delay in reply. I solved the problem by creating a Middlewares\ST\netxduo\reserved\ folder where I put the files. Otherwise, MX deletes these files from the Middlewares\ST\netxduo\common\src\ folder. I suspect it is some difference in the Netxduo configuration. Please tell me how I can share the project with you.
Thanks Javier
Ghofrane GSOURI
Hello @JVica.1​
Thank you for your reply
You need to ZIP your project and go to this icon
0693W00000Y7DhmQAF.pngin order to attach it .
I' will be waiting for your feedback
Thx
Ghofrane
JVica.1
Hi Gofrane,
Project attached.
Javier
