Need Guidance on the Ethernet TCP socket creation on STM32N6570-DK
MownishBugatha
6 REPLIES 6
Andrew Neil
Have you checked for examples in CubeMX and/or the STM32CubeN6 firmware package ?
https://www.st.com/en/microcontrollers-microprocessors/stm32n657x0.html#tools-software
https://www.st.com/en/microcontrollers-microprocessors/stm32n657x0.html#documentation
How to write your question to maximize your chances to find a solution
MownishBugatha
There is one Example NX_WEB_SERVER for the Board it uses the DHCP, but I need the Static IP Configuration, and I tried but I am Unable to bring up and open the TCP Socket, so I have Mentioned Need of guidance in order to configure the static IP and TCP Transactions
It would have been helpful to have explained that in the original post - rather than just leaving it blank, and giving us nothing to go on. We are not mind readers.
The better the information you provide, the more likely you are to get useful replies.
So this: STM32N6570-DK NX_Web_server example: Where to place .nx_data ?
And this: Break at address "0x18003a1a" with no debug information available
MownishBugatha
ok thanks I will modify the Questionnaire
It's best not to modify a question after it's already had replies - that tends to make the existing replies no longer make sense!
Add further detail in a reply.
MownishBugatha
ok
