Issue with UART/USB Rx interrupt in STM32F407VGT6 and using DP83848 LWIP stack.
‎2025-03-17 10:47 PM
Hello, Good morning all,
I am doing a project with STM32F407VGT6 and DP83848 Ethernet Controller using LWIP stack. My requirement is UART/USB to Ethernet. I have enabled global interrupt and IRQ Handlers for both USB & UART, but when I send data from UART/USB RX interrupt is not enabling by MCU. Please suggest me the solution to enable USB/UART interrupt for receiving data.
Thanks and regards
Satyanarayana
- Labels:
Interrupt
‎2025-03-19 5:56 AM
Hello @Satya_VVM
Are you sure there is a data transfer on the bus ? Could you please check the trafic on the bus using logic analyser ?
Omar
‎2025-03-20 3:35 AM
Hello @Saket_Om
Thanks a lot for your valued support, actually there was an hardware issue.
Satyanarayana
- « Previous
- 1
- 2
- Next »
