In stm32l4xx_hal.c, there is a bug with HAL_SYSCFG_EnableMemorySwappingBank().
pgspro1
The code is identical to the Disable version. The enable swapping is currently this:
void HAL_SYSCFG_EnableMemorySwappingBank(void)
 *(__IO uint32_t *)FB_MODE_BB = 0x00000000UL;
 and instead of = 0, it should be the equivalent of 0x100.
Also, the lower 3-bits should be maintained since they are MEM_MODE bits. As it turns out, %000 is Main Flash memory, which is probably good for most, but it's still a bad implementation.
Imen.D
Hi @pgspro1​ ,
This is a Bit Banding access, not a full register access.
/* Alias word address of FB_MODE bit */
#define MEMRMP_OFFSET             SYSCFG_OFFSET
#define FB_MODE_BitNumber         8U
#define FB_MODE_BB                (PERIPH_BB_BASE + (MEMRMP_OFFSET * 32U) + (FB_MODE_BitNumber * 4U))
So, there is a bug and the fix should be :
  *(__IO uint32_t *)FB_MODE_BB = 0x00000001UL;
Avantage of the bit banding, No effects on the other bits of the SYSCFG_MEMRMP register with this single instruction.
Thanks for highlighting this issue.
Kind Regards,
Imen.
Imen
3 REPLIES 3
Imen.D
We will check this issue internally and we will come back to you.
Kind Regards,
Imen
Imen
Imen.D
Hi @pgspro1​ ,
Kind Regards,
Imen.
Imen
Imen.D
This issue is fixed with the new release of STM32CubeL4 V1.14.0 available on the ST web site.
Imen.
Imen
