I2C bootloader not working on stm32G030
2022-03-14 9:53 PM
we are using stm32G030, we need to update firmware using I2C, we are using st-link v3 and we connected (SCL,SDA,GND), opened cube programmer to update firmware we selected I2C and and given i2c address as 0xAD/0xAC but we are getting I2C_BRG_ERR,
what is the procedure to update firmware using i2c bootloader, whether there are specific procedure to update it.
to use st-link v3 whether we need to update any software for stlink
Thanks and Regards,
Pradeep Gamidi.
Bootloader
I2C
ST-Link
STM32G0 Series
2022-03-31 8:04 AM
Hello @pGami.1 ,
Did you finally manage to resolve your issue ?
Make sure to follow the I2C configuration for accessing the bootloader as described in AN2606
The STM32G03xxx bootloader is activated by applying Pattern 11 (described in Table 2: Bootloader activation patterns) and note that STM32G030x don’t have BOOT_LOCK(bit), so consider that when using pattern 11.
Imen
Imen
