I was trying to do file write operation on SD card and it worked for few days and now its giving "FR NOT ENABLED" error.
2023-03-16 9:07 PM
I was able to do file write operation on Sd card and usb both successfully , but after few days it is continuously giving me FR NOT ENABLED error, i formatted both devices and scanned if they might have malfunctioned it worked after formatting but now i have to again and again format both of them to make the file operation work. Is there any solution for FR NOT ENABLED Error? This error says there is not enough space on logical drive whereas the card is completely empty and has enough space.
- Labels:
FatFS
2023-03-17 12:35 AM
From description not really got much idea about your hardware or software implementation.
The file system is dependent on the block level DISKIO functions working properly.
2023-03-17 2:23 AM
Hello @smore.1,
I'm not sure if this helps but generally when you use 5V supply voltage, SD Card module works better. So, it's important to ensure that the power supply is stable.
2023-03-20 12:12 AM
I need the solution for FR NOT ENABLED.
How can i make my system error free ?
What are the causes for getting FR NOT ENABLED error? And how can i tackle it?
