2024-04-20 01:24 PM
I want to use a 20x4 LCD without I2C on the Nucleo-F030R8 board. But many libraries are programmed on the I2C protocol. Is there a 20x4 LCD library that doesn't use I2C?
2024-04-20 01:31 PM - edited 2024-04-20 06:13 PM
You'll need to be much more specific about make, model, manufacturer of said "20x4 LCD"
Link to a data sheet.
Show how it is interfaced?
2024-04-20 05:08 PM
you have to be more specific. I did a lot of those long time ago and it was fun
it has 8 lines of data lines
H/L register select signal pin
H/L read/write signal
H/ L enable signal
see data sheet for the display what you want to display,
use I/O pins to write 0 or 1 then use control pins to send the data to the display very simple
2024-04-20 05:24 PM
I have used MC42005 type displays. Just be aware of their logic voltage levels, and they have specific timing to some of the instructions.
I hope this helps.
Kind regards
Pedro
