I have a lot of questions about USBX
Options
2021-07-26 7:41 PM
- How does the FIFO created in MX_USB_Device_Init() match the endpoint?
- In the USBX document of Azure, the descriptor is directly made into an array, while the sample program uses a lot of functions to implement it. What are the benefits of this? Not easy to analyze
- ux_app_parameters_change() corresponds to CDC Control. How can I operate CDC Control to change the baud rate and other operations?
- ux_device_class_cdc_acm_read() reads data. How to make sure it reads the correct endpoint data?
- Initialize USBX Memory size is 32K Is this the smallest memory value? Can it be reduced
Labels:
- Labels:
AzureRTOS
STM32Cube MCU Packages
USB
Options
2021-07-29 4:11 AM
Hello @arilink ,
Your questions have been raised internally and I will keep you posted.
Thanks for your contribution.
BeST Regards,
Walid
