I am trying to run UART on STM32 MCU using HAL library for one of my application. I would like to receive packet of data which I am not able to do.
Can you please guide me in this? I have provide details below.
‎2022-02-17 11:45 PM
I have created an application where I can transmit and receive data over UART port one by one. I am also able to receive packets in sets where I know the size of the data.
But in my case, I want to receive data packet of unknown length and read from receive buffer one by one which I am not able to do. When I send a packet of data using serial terminal, UART function only reads the first character and then ignore the remaining.
I have added the code segment for the reference below. The code compiles correctly and is working. It's only when I send a packet "Hello" from the terminal(real term), the code reads only 'H'. In my application the packet size varies, hence I can't mention fixed size in function HAL_UART_Receive_IT.
-Regards
Hrishikesh
int iRxFlag = 0;
int main(void)
char cData;
HAL_Init();
MX_GPIO_Init();
MX_UART4_Init();
while(1)
if(iRxFlag)
iRxFlag = 0;
HAL_UART_Transmit(&huart4, (uint8_t*)&cData, 1, 1);
HAL_UART_Receive_IT(&huart4, (uint8_t*)&cData, 1);
HAL_Delay(250);
return 0;
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
iRxFlag = 1;
Hrishikesh
STM32Cube MCU Packages
UART-USART
‎2022-02-18 12:28 AM
You can call HAL_UART_Receive_IT again at the end of HAL_UART_RxCpltCallback.
But: since it all goes through HAL (=takes time)you risk missing input characters.
You will be better off by using the idle interupt, see https://community.st.com/s/feed/0D53W00001AzphUSAR or using DMA as an input FIFO and read at your own pace.
See https://github.com/MaJerle/stm32-usart-uart-dma-rx-tx
hth
KnarfB
‎2022-02-18 12:33 AM
Thank you KnarfB for your suggestion. I will try this method.
-Thanks & Regards
Hrishikesh
Hrishikesh
‎2022-02-18 6:14 AM
Your code is bad BAD
//this must be global for IT not in func or main
volatile uint8_t cData[2]; //better is bigger buff here used only 1 byte
HAL_UART_Receive_IT(&huart4, cData, 1);
//started first byte wait read
while(1)
if(iRxFlag)
iRxFlag = 0;
HAL_UART_Transmit(&huart4, cData+1, 1, 1);
return 0;
iRxFlag = 1;
//better is copy to protect overwrite
cData[1]=cData[0];
‎2022-02-18 3:48 PM
In topic author's code iRxFlag variable must be volatile.
‎2022-02-18 10:09 PM
Thank you for your suggestion. I had also tried this method.
The method which you had suggested works when time between the 2 data is long. In case, where the entire packet is to be read, this method doesn't work. Also in my case, my packet length is unknown.
-Regards
Hrishikesh
‎2022-02-18 10:42 PM
Then try the other methods suggested. Searcgh for "hal uart receive idle dma". These are used in many projects.
hth
KnarfB
‎2022-02-19 1:34 AM
My code is only example and ofcourse cant work for stream data read and transmit in one time.
your words then do it ...
