2024-07-08 07:24 AM
/* USER CODE BEGIN Header */
* @file ux_device_msc.c
* @author MCD Application Team
* @brief USBX Device applicative file
* @attention
* Copyright (c) 2024 STMicroelectronics.
* All rights reserved.
/* USER CODE END Header */
#include "ux_device_msc.h"
#include <stdio.h>
#include "main.h"
#include "fx_stm32_sd_driver.h"
/* USER CODE END Includes */
#include "fx_api.h"
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
enum {
SD_WRITE_FLAG = 0x01,
SD_READ_FLAG = 0x02,
/* USER CODE END PM */
/* USER CODE BEGIN PV */
extern SD_HandleTypeDef hsd1;
extern HAL_SD_CardInfoTypeDef sd_info;
extern TX_EVENT_FLAGS_GROUP sdmmc_event;
extern FX_MEDIA sdio_disk;
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
static INT check_sd_status(uint32_t instance)
uint32_t start = tx_time_get();
while (tx_time_get() - start < 100) {
if (fx_stm32_sd_get_status(instance) == 0) {
return 0;
return 1;
/* USER CODE END 0 */
* @brief USBD_STORAGE_Activate
* This function is called when insertion of a storage device.
* @PAram storage_instance: Pointer to the storage class instance.
* @retval none
VOID USBD_STORAGE_Activate(VOID *storage_instance)
/* USER CODE BEGIN USBD_STORAGE_Activate */
UX_PARAMETER_NOT_USED(storage_instance);
printf("USBD_STORAGE_Activate\n");
/* USER CODE END USBD_STORAGE_Activate */
return;
* @brief USBD_STORAGE_Deactivate
* This function is called when extraction of a storage device.
* @retval none
VOID USBD_STORAGE_Deactivate(VOID *storage_instance)
return;
* @brief USBD_STORAGE_Read
* This function is invoked to read from media.
* @PAram storage_instance : Pointer to the storage class instance.
* @PAram lun: Logical unit number is the command is directed to.
* @PAram data_pointer: Address of the buffer to be used for reading or writing.
* @PAram number_blocks: number of sectors to read/write.
* @PAram lba: Logical block address is the sector address to read.
* @PAram media_status: should be filled out exactly like the media status
* callback return value.
* @retval status
UINT USBD_STORAGE_Read(VOID *storage_instance, ULONG lun, UCHAR *data_pointer,
ULONG number_blocks, ULONG lba, ULONG *media_status)
UINT status = UX_SUCCESS;
/* USER CODE BEGIN USBD_STORAGE_Read */
UX_PARAMETER_NOT_USED(lun);
// UX_PARAMETER_NOT_USED(data_pointer);
// UX_PARAMETER_NOT_USED(number_blocks);
// UX_PARAMETER_NOT_USED(lba);
UX_PARAMETER_NOT_USED(media_status);
ULONG WriteFlags = 0;
status = UX_ERROR;
status = check_sd_status(0);
if (status) {
printf("SD card not ready\n");
return status;
/* Start the Dma write */
status = fx_stm32_sd_read_blocks(0, (UINT *)data_pointer, lba, number_blocks);
if(status != HAL_OK) {
printf("HAL_SD_ReadBlocks_DMA failed\n");
/* Wait on readflag until SD card is ready to use for new operation */
tx_event_flags_get(&sdmmc_event,
SD_READ_FLAG,
TX_OR_CLEAR,
&WriteFlags,
TX_WAIT_FOREVER);
/* USER CODE END USBD_STORAGE_Read */
return status;
* @brief USBD_STORAGE_Write
* This function is invoked to write in media.
* @retval status
UINT USBD_STORAGE_Write(VOID *storage_instance, ULONG lun, UCHAR *data_pointer,
/* USER CODE BEGIN USBD_STORAGE_Write */
// UX_PARAMETER_NOT_USED(lun);
ULONG ReadFlags = 0U;
status = UX_ERROR;
if (status) {
return status;
status = fx_stm32_sd_write_blocks(0, (UINT *)data_pointer, lba, number_blocks);
printf("HAL_SD_WriteBlocks_DMA failed\n");
/* Wait on writeflag until SD card is ready to use for new operation */
SD_WRITE_FLAG,
TX_OR_CLEAR,
&ReadFlags,
TX_WAIT_FOREVER);
/* USER CODE END USBD_STORAGE_Write */
return status;
* @brief USBD_STORAGE_Flush
* This function is invoked to flush media.
* @retval status
UINT USBD_STORAGE_Flush(VOID *storage_instance, ULONG lun, ULONG number_blocks,
/* USER CODE BEGIN USBD_STORAGE_Flush */
// status = UX_ERROR;
/* USER CODE END USBD_STORAGE_Flush */
return status;
* @brief USBD_STORAGE_Status
* This function is invoked to obtain the status of the device.
* @PAram media_id: is not currently used.
* @retval status
UINT USBD_STORAGE_Status(VOID *storage_instance, ULONG lun, ULONG media_id,
/* USER CODE BEGIN USBD_STORAGE_Status */
UX_PARAMETER_NOT_USED(media_id);
/* USER CODE END USBD_STORAGE_Status */
return status;
* @brief USBD_STORAGE_Notification
* This function is invoked to obtain the notification of the device.
* @PAram notification_class: specifies the class of notification.
* @PAram media_notification: response for the notification.
* @PAram media_notification_length: length of the response buffer.
* @retval status
UINT USBD_STORAGE_Notification(VOID *storage_instance, ULONG lun, ULONG media_id,
ULONG notification_class, UCHAR **media_notification,
ULONG *media_notification_length)
/* USER CODE BEGIN USBD_STORAGE_Notification */
UX_PARAMETER_NOT_USED(notification_class);
UX_PARAMETER_NOT_USED(media_notification);
UX_PARAMETER_NOT_USED(media_notification_length);
/* USER CODE END USBD_STORAGE_Notification */
return status;
* @brief USBD_STORAGE_GetMediaLastLba
* Get Media last LBA.
* @PAram none
* @retval last lba
ULONG USBD_STORAGE_GetMediaLastLba(VOID)
ULONG LastLba = 0U;
/* USER CODE BEGIN USBD_STORAGE_GetMediaLastLba */
LastLba = (ULONG)(sd_info.BlockNbr - 1);
/* USER CODE END USBD_STORAGE_GetMediaLastLba */
return LastLba;
* @brief USBD_STORAGE_GetMediaBlocklength
* Get Media block length.
* @PAram none.
* @retval block length.
ULONG USBD_STORAGE_GetMediaBlocklength(VOID)
ULONG MediaBlockLen = 0U;
/* USER CODE BEGIN USBD_STORAGE_GetMediaBlocklength */
MediaBlockLen = (ULONG) sd_info.BlockSize;
/* USER CODE END USBD_STORAGE_GetMediaBlocklength */
return MediaBlockLen;
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
2024-07-08 09:14 AM - edited 2024-07-08 09:14 AM
filex_media_open() is not a standard function in the FileX stack or ST's stack. Instead, it seems to be a custom function. Could you provide more details about the function definition?
2024-07-08 09:23 AM
>USBX MSC cannot be used when using filex_media_open()
-- you mean: fx_media_open(..) ?
2024-07-08 04:20 PM
oh, i'm sorry fx_media_open() is right
void fx_app_thread_entry(ULONG thread_input)
UINT sd_status = FX_SUCCESS;
UINT nor_ospi_status = FX_SUCCESS;
/* USER CODE BEGIN fx_app_thread_entry 0*/
/* USER CODE END fx_app_thread_entry 0*/
/* Open the SD disk driver */
sd_status = fx_media_open(&sdio_disk, FX_SD_VOLUME_NAME, fx_stm32_sd_driver, (VOID *)FX_NULL, (VOID *) fx_sd_media_memory, sizeof(fx_sd_media_memory));
// /* Check the media open sd_status */
if (sd_status != FX_SUCCESS)
/* USER CODE BEGIN SD DRIVER get info error */
while(1);
/* USER CODE END SD DRIVER get info error */
/* Open the OCTO-SPI NOR driver */
nor_ospi_status = fx_media_open(&nor_ospi_flash_disk, FX_NOR_OSPI_VOLUME_NAME, fx_stm32_levelx_nor_driver, (VOID *)LX_NOR_OSPI_DRIVER_ID, (VOID *) fx_nor_ospi_media_memory, sizeof(fx_nor_ospi_media_memory));
/* Check the media open nor_ospi_status */
if (nor_ospi_status != FX_SUCCESS)
/* USER CODE BEGIN OCTO-SPI NOR open error */
while(1);
/* USER CODE END OCTO-SPI NOR open error */
/* USER CODE BEGIN fx_app_thread_entry 1*/
UINT status;
CHAR entry_name[256];
UINT attributes;
ULONG size;
UINT year;
UINT month;
UINT day;
UINT hour;
UINT minute;
UINT second;
/* Get the next directory entry in the default directory with full information. */
printf("nor flash disk directory:\n");
do {
status = fx_directory_next_full_entry_find(&nor_ospi_flash_disk, entry_name, &attributes, &size,
&year, &month, &day,
&hour, &minute, &second);
if (status == FX_SUCCESS) {
/* Process the directory entry. */
printf("File: %s, Size: %lu, Date: %02u/%02u/%04u, Time: %02u:%02u:%02u\n",
entry_name, size, day, month, year, hour, minute, second);
} while (status == FX_SUCCESS);
printf("sd disk directory:\n");
do {
status = fx_directory_next_full_entry_find(&sdio_disk, entry_name, &attributes, &size,
status = fx_media_close(&sdio_disk);
if (status) {
printf("Failed to close sd disk: %x\n", status);
/* USER CODE END fx_app_thread_entry 1*/
2024-07-08 04:25 PM
oh, i'm sorry. fx_media_open () is correct. I added the code below.
2024-07-08 04:27 PM
oh, i'm sorry. fx_media_open () is correct. I added the code below~
2024-07-09 12:48 AM
One sorry is enough.. 🙂
> USBX MSC cannot be used when using filex_media_open().
In your code i see open for sd-card and nor-flash - so what about the usb problem ?
