How to work with SD Card FileX and USBX MSC on stm32h573i-dk
bangjinyoung
I'd like to use both FileX and USBX MSC as SD cards on stm32h573i-dk. FileX and USBX MSC worked respectively with reference to the example. USBX MSC cannot be used when using filex_media_open().
/* USER CODE BEGIN Header */ /** ****************************************************************************** * @file ux_device_msc.c * @author MCD Application Team * @brief USBX Device applicative file ****************************************************************************** * @attention * * Copyright (c) 2024 STMicroelectronics. * All rights reserved. * * This software is licensed under terms that can be found in the LICENSE file * in the root directory of this software component. * If no LICENSE file comes with this software, it is provided AS-IS. * ****************************************************************************** */ /* USER CODE END Header */ /* Includes ------------------------------------------------------------------*/ #include "ux_device_msc.h" /* Private includes ----------------------------------------------------------*/ /* USER CODE BEGIN Includes */ #include <stdio.h> #include "main.h" #include "fx_stm32_sd_driver.h" /* USER CODE END Includes */ #include "fx_api.h" /* Private typedef -----------------------------------------------------------*/ /* USER CODE BEGIN PTD */ /* USER CODE END PTD */ /* Private define ------------------------------------------------------------*/ /* USER CODE BEGIN PD */ /* USER CODE END PD */ /* Private macro -------------------------------------------------------------*/ /* USER CODE BEGIN PM */ enum { SD_WRITE_FLAG = 0x01, SD_READ_FLAG = 0x02, }; /* USER CODE END PM */ /* Private variables ---------------------------------------------------------*/ /* USER CODE BEGIN PV */ extern SD_HandleTypeDef hsd1; extern HAL_SD_CardInfoTypeDef sd_info; extern TX_EVENT_FLAGS_GROUP sdmmc_event; extern FX_MEDIA sdio_disk; /* USER CODE END PV */ /* Private function prototypes -----------------------------------------------*/ /* USER CODE BEGIN PFP */ /* USER CODE END PFP */ /* Private user code ---------------------------------------------------------*/ /* USER CODE BEGIN 0 */ static INT check_sd_status(uint32_t instance) { uint32_t start = tx_time_get(); while (tx_time_get() - start < 100) { if (fx_stm32_sd_get_status(instance) == 0) { return 0; } } return 1; } /* USER CODE END 0 */ /** * @brief USBD_STORAGE_Activate * This function is called when insertion of a storage device. * @PAram storage_instance: Pointer to the storage class instance. * @retval none */ VOID USBD_STORAGE_Activate(VOID *storage_instance) { /* USER CODE BEGIN USBD_STORAGE_Activate */ UX_PARAMETER_NOT_USED(storage_instance); printf("USBD_STORAGE_Activate\n"); /* USER CODE END USBD_STORAGE_Activate */ return; } /** * @brief USBD_STORAGE_Deactivate * This function is called when extraction of a storage device. * @PAram storage_instance: Pointer to the storage class instance. * @retval none */ VOID USBD_STORAGE_Deactivate(VOID *storage_instance) { /* USER CODE BEGIN USBD_STORAGE_Activate */ UX_PARAMETER_NOT_USED(storage_instance); printf("USBD_STORAGE_Activate\n"); /* USER CODE END USBD_STORAGE_Activate */ return; } /** * @brief USBD_STORAGE_Read * This function is invoked to read from media. * @PAram storage_instance : Pointer to the storage class instance. * @PAram lun: Logical unit number is the command is directed to. * @PAram data_pointer: Address of the buffer to be used for reading or writing. * @PAram number_blocks: number of sectors to read/write. * @PAram lba: Logical block address is the sector address to read. * @PAram media_status: should be filled out exactly like the media status * callback return value. * @retval status */ UINT USBD_STORAGE_Read(VOID *storage_instance, ULONG lun, UCHAR *data_pointer, ULONG number_blocks, ULONG lba, ULONG *media_status) { UINT status = UX_SUCCESS; /* USER CODE BEGIN USBD_STORAGE_Read */ UX_PARAMETER_NOT_USED(storage_instance); UX_PARAMETER_NOT_USED(lun); // UX_PARAMETER_NOT_USED(data_pointer); // UX_PARAMETER_NOT_USED(number_blocks); // UX_PARAMETER_NOT_USED(lba); UX_PARAMETER_NOT_USED(media_status); ULONG WriteFlags = 0; status = UX_ERROR; status = check_sd_status(0); if (status) { printf("SD card not ready\n"); return status; } /* Start the Dma write */ status = fx_stm32_sd_read_blocks(0, (UINT *)data_pointer, lba, number_blocks); if(status != HAL_OK) { printf("HAL_SD_ReadBlocks_DMA failed\n"); } /* Wait on readflag until SD card is ready to use for new operation */ tx_event_flags_get(&sdmmc_event, SD_READ_FLAG, TX_OR_CLEAR, &WriteFlags, TX_WAIT_FOREVER); /* USER CODE END USBD_STORAGE_Read */ return status; } /** * @brief USBD_STORAGE_Write * This function is invoked to write in media. * @PAram storage_instance : Pointer to the storage class instance. * @PAram lun: Logical unit number is the command is directed to. * @PAram data_pointer: Address of the buffer to be used for reading or writing. * @PAram number_blocks: number of sectors to read/write. * @PAram lba: Logical block address is the sector address to read. * @PAram media_status: should be filled out exactly like the media status * callback return value. * @retval status */ UINT USBD_STORAGE_Write(VOID *storage_instance, ULONG lun, UCHAR *data_pointer, ULONG number_blocks, ULONG lba, ULONG *media_status) { UINT status = UX_SUCCESS; /* USER CODE BEGIN USBD_STORAGE_Write */ UX_PARAMETER_NOT_USED(storage_instance); // UX_PARAMETER_NOT_USED(lun); // UX_PARAMETER_NOT_USED(data_pointer); // UX_PARAMETER_NOT_USED(number_blocks); // UX_PARAMETER_NOT_USED(lba); UX_PARAMETER_NOT_USED(media_status); ULONG ReadFlags = 0U; status = UX_ERROR; status = check_sd_status(0); if (status) { printf("SD card not ready\n"); return status; } /* Start the Dma write */ status = fx_stm32_sd_write_blocks(0, (UINT *)data_pointer, lba, number_blocks); if(status != HAL_OK) { printf("HAL_SD_WriteBlocks_DMA failed\n"); } /* Wait on writeflag until SD card is ready to use for new operation */ tx_event_flags_get(&sdmmc_event, SD_WRITE_FLAG, TX_OR_CLEAR, &ReadFlags, TX_WAIT_FOREVER); /* USER CODE END USBD_STORAGE_Write */ return status; } /** * @brief USBD_STORAGE_Flush * This function is invoked to flush media. * @PAram storage_instance : Pointer to the storage class instance. * @PAram lun: Logical unit number is the command is directed to. * @PAram number_blocks: number of sectors to read/write. * @PAram lba: Logical block address is the sector address to read. * @PAram media_status: should be filled out exactly like the media status * callback return value. * @retval status */ UINT USBD_STORAGE_Flush(VOID *storage_instance, ULONG lun, ULONG number_blocks, ULONG lba, ULONG *media_status) { UINT status = UX_SUCCESS; /* USER CODE BEGIN USBD_STORAGE_Flush */ UX_PARAMETER_NOT_USED(storage_instance); UX_PARAMETER_NOT_USED(lun); UX_PARAMETER_NOT_USED(number_blocks); UX_PARAMETER_NOT_USED(lba); UX_PARAMETER_NOT_USED(media_status); // status = UX_ERROR; /* USER CODE END USBD_STORAGE_Flush */ return status; } /** * @brief USBD_STORAGE_Status * This function is invoked to obtain the status of the device. * @PAram storage_instance : Pointer to the storage class instance. * @PAram lun: Logical unit number is the command is directed to. * @PAram media_id: is not currently used. * @PAram media_status: should be filled out exactly like the media status * callback return value. * @retval status */ UINT USBD_STORAGE_Status(VOID *storage_instance, ULONG lun, ULONG media_id, ULONG *media_status) { UINT status = UX_SUCCESS; /* USER CODE BEGIN USBD_STORAGE_Status */ UX_PARAMETER_NOT_USED(storage_instance); UX_PARAMETER_NOT_USED(lun); UX_PARAMETER_NOT_USED(media_id); UX_PARAMETER_NOT_USED(media_status); // status = UX_ERROR; /* USER CODE END USBD_STORAGE_Status */ return status; } /** * @brief USBD_STORAGE_Notification * This function is invoked to obtain the notification of the device. * @PAram storage_instance : Pointer to the storage class instance. * @PAram lun: Logical unit number is the command is directed to. * @PAram media_id: is not currently used. * @PAram notification_class: specifies the class of notification. * @PAram media_notification: response for the notification. * @PAram media_notification_length: length of the response buffer. * @retval status */ UINT USBD_STORAGE_Notification(VOID *storage_instance, ULONG lun, ULONG media_id, ULONG notification_class, UCHAR **media_notification, ULONG *media_notification_length) { UINT status = UX_SUCCESS; /* USER CODE BEGIN USBD_STORAGE_Notification */ UX_PARAMETER_NOT_USED(storage_instance); UX_PARAMETER_NOT_USED(lun); UX_PARAMETER_NOT_USED(media_id); UX_PARAMETER_NOT_USED(notification_class); UX_PARAMETER_NOT_USED(media_notification); UX_PARAMETER_NOT_USED(media_notification_length); // status = UX_ERROR; /* USER CODE END USBD_STORAGE_Notification */ return status; } /** * @brief USBD_STORAGE_GetMediaLastLba * Get Media last LBA. * @PAram none * @retval last lba */ ULONG USBD_STORAGE_GetMediaLastLba(VOID) { ULONG LastLba = 0U; /* USER CODE BEGIN USBD_STORAGE_GetMediaLastLba */ LastLba = (ULONG)(sd_info.BlockNbr - 1); /* USER CODE END USBD_STORAGE_GetMediaLastLba */ return LastLba; } /** * @brief USBD_STORAGE_GetMediaBlocklength * Get Media block length. * @PAram none. * @retval block length. */ ULONG USBD_STORAGE_GetMediaBlocklength(VOID) { ULONG MediaBlockLen = 0U; /* USER CODE BEGIN USBD_STORAGE_GetMediaBlocklength */ MediaBlockLen = (ULONG) sd_info.BlockSize; /* USER CODE END USBD_STORAGE_GetMediaBlocklength */ return MediaBlockLen; } /* USER CODE BEGIN 1 */ /* USER CODE END 1 */
View more
6 REPLIES 6
FBL
Hi @bangjinyoung
filex_media_open() is not a standard function in the FileX stack or ST's stack. Instead, it seems to be a custom function. Could you provide more details about the function definition?
AScha.3
-- you mean:   fx_media_open(..) ?
bangjinyoung
oh, i'm sorry fx_media_open() is right
void fx_app_thread_entry(ULONG thread_input) { UINT sd_status = FX_SUCCESS; UINT nor_ospi_status = FX_SUCCESS; /* USER CODE BEGIN fx_app_thread_entry 0*/ /* USER CODE END fx_app_thread_entry 0*/ /* Open the SD disk driver */ sd_status = fx_media_open(&sdio_disk, FX_SD_VOLUME_NAME, fx_stm32_sd_driver, (VOID *)FX_NULL, (VOID *) fx_sd_media_memory, sizeof(fx_sd_media_memory)); // /* Check the media open sd_status */ if (sd_status != FX_SUCCESS) { /* USER CODE BEGIN SD DRIVER get info error */ while(1); /* USER CODE END SD DRIVER get info error */ } /* Open the OCTO-SPI NOR driver */ nor_ospi_status = fx_media_open(&nor_ospi_flash_disk, FX_NOR_OSPI_VOLUME_NAME, fx_stm32_levelx_nor_driver, (VOID *)LX_NOR_OSPI_DRIVER_ID, (VOID *) fx_nor_ospi_media_memory, sizeof(fx_nor_ospi_media_memory)); /* Check the media open nor_ospi_status */ if (nor_ospi_status != FX_SUCCESS) { /* USER CODE BEGIN OCTO-SPI NOR open error */ while(1); /* USER CODE END OCTO-SPI NOR open error */ } /* USER CODE BEGIN fx_app_thread_entry 1*/ UINT status; CHAR entry_name[256]; UINT attributes; ULONG size; UINT year; UINT month; UINT day; UINT hour; UINT minute; UINT second; /* Get the next directory entry in the default directory with full information. */ printf("nor flash disk directory:\n"); do { status = fx_directory_next_full_entry_find(&nor_ospi_flash_disk, entry_name, &attributes, &size, &year, &month, &day, &hour, &minute, &second); if (status == FX_SUCCESS) { /* Process the directory entry. */ printf("File: %s, Size: %lu, Date: %02u/%02u/%04u, Time: %02u:%02u:%02u\n", entry_name, size, day, month, year, hour, minute, second); } } while (status == FX_SUCCESS); /* Get the next directory entry in the default directory with full information. */ printf("sd disk directory:\n"); do { status = fx_directory_next_full_entry_find(&sdio_disk, entry_name, &attributes, &size, &year, &month, &day, &hour, &minute, &second); if (status == FX_SUCCESS) { /* Process the directory entry. */ printf("File: %s, Size: %lu, Date: %02u/%02u/%04u, Time: %02u:%02u:%02u\n", entry_name, size, day, month, year, hour, minute, second); } } while (status == FX_SUCCESS); status = fx_media_close(&sdio_disk); if (status) { printf("Failed to close sd disk: %x\n", status); } /* USER CODE END fx_app_thread_entry 1*/ }
View more
oh, i'm sorry. fx_media_open () is correct. I added the code below.
oh, i'm sorry. fx_media_open () is correct. I added the code below~
One sorry is enough.. :)
In your code i see open for sd-card and nor-flash - so what about the usb problem ?
