How to store a file in pendrive as pdf in STM32 using Mass Storage Class and FATFS?
KSing.8
18 REPLIES 18
KnarfB
Just copy the .pdf to your STM32 using Mass Storage Class and FATFS.
hth
KnarfB
KSing.8
The thing is with .pdf i am able to create a file but i am not able to open that file.
Check content in file manager or viewer. Check integrity and that it contains what your expect / wrote.
If you update on-the-fly generate a Media Changed Sense Code, so the PC Side OS will reread.​
GagandeepSingh.6
Pdf file open in note++​
GagandeepSingh.6
Without note++ , I m not able to open pdf file ​
Please fix the problem ​
Could it be that the PDF is not correctly constructed/written?
Not really my job, perhaps someone on your team can work on it, or a supervisor/manager for the project?
By Note++ you must mean Notepad++, right?
Notepad++ is a text editor and typically displays PDF only as a jumble of control characters - provided it is a standards-compliant PDF.
How did you create the PDF?
/Peter
