How to solve this problem - flashed blinky into boot location ?
MQi.1
Senior II
When I flashed the blinky demo code into a STM32F103 minimal circuit board, the boot0 and boot1 were all in boot mode, so the board now don't work. What I thought is flash the firmware again into boot location when boot0 was in boot mode, any suggestions and warnings before I try this?
3 REPLIES 3
The ROM bootloader is in, well, ROM and cannot be overwritten.
The state of the BOOTx pins has no bearing on where something is flashed, barring some bizarre custom bootloader code.
If you have a blue pill or other board which relies on a user bootloader, you'll need to reflash that.
MQi.1
Senior II
After some research, I found my board was a clone blue pill with STM32F103C6T6 on it, and for the boot pins I have these notes:
  1. When the code run normally, both boot0 and boot1 should be in "-";
  2. When I go to program it by ST-Link, both boot 0 and boot1 should be in ""- ;
  3. When I program it with a USB-TTL convertor, boot0 should be in "-", while boot1 in "+";
  4. After I programmed it by USB-TTL, boot0 should be returned to "-", other wise, all the code has been programmed into it would be erased.
Is that right?
Is that right?
