predd.21
May 9, 2024 4:36 PM UTC
how to merge bootloader and application bin
hello ST users,
i was trying to merge bootloader bin file and application bin file any possible solutions please help me .
May 9, 2024 4:43 PM UTC
Could you use C file functions? fopen, fread, fwrite, fclose ?
COPY  /b  a.bin+b.bin  c.bin
Most situations you actually want to convey meta-data like address and size, sort of thing an OBJECT FILE would do?
See also .DFU for a standardized/documented format for encapsulating binary data.
Radosław
May 10, 2024 7:01 AM UTC
Use Srecord, or .....
In linker script of your aplication :
Create proper memory region for BOOTLOADER
and....
TARGET(binary)
INPUT(bootloader.bin)
OUTPUT_FORMAT(default)
TARGET(default)
SECTIONS
 .bootloader :
 bootloader.bin (.data)
 . = ALIGN (0x4);
 } > BOOTROM
predd.21
predd.21Author
May 16, 2024 6:53 AM UTC
i have modified in the linker script of applicationi have modified in the linker script of applicationin application adding linker pathin application adding linker pathplepplerrorerror
predd.21
predd.21Author
May 16, 2024 7:41 AM UTC
PLEASE CHECK THIS ERROR
make -j8 all
arm-none-eabi-gcc -o "appl.elf" @"objects.list" -Wl,--start-group -Wl,--end-group -mcpu=cortex-m0plus -T"C:\Users\91910\STM32CubeIDE\workspace_1.14.1\appl\STM32G0B1CBTX_FLASH.ld" --specs=nosys.specs -Wl,-Map="appl.map" -Wl,--cref -static --specs=nano.specs -mfloat-abi=soft -mthumb -Wl,--start-group -lc -lm -Wl,--end-group
C:/ST/STM32CubeIDE_1.14.1/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.100.202309141235/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\91910\STM32CubeIDE\workspace_1.14.1\appl\STM32G0B1CBTX_FLASH.ld:78: ignoring invalid character `\342' in script
C:/ST/STM32CubeIDE_1.14.1/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.100.202309141235/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\91910\STM32CubeIDE\workspace_1.14.1\appl\STM32G0B1CBTX_FLASH.ld:78: ignoring invalid character `\200' in script
C:/ST/STM32CubeIDE_1.14.1/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.100.202309141235/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe:C:\Users\91910\STM32CubeIDE\workspace_1.14.1\appl\STM32G0B1CBTX_FLASH.ld:78: ignoring invalid character `\215' in script
MM..1
May 10, 2024 7:31 AM UTC
Explain for what, why not two hex merge?
Radosław
May 16, 2024 8:56 AM UTC
Some wrong character,   format correcly added lines in linker script, (maybe some unprintable sign was added)
