How to create a file system on a SD card using SPI
HDaji.1
Moved to main forum from How to create a file system on a SD card using STM32CubeIDE for better visibility & discussion.
Hi @ST AME Support NF ,
Is there any guide on using SPI to create a file system on SD card?
Andrew Neil
The question is really, "how to configure FatFs to use SPI" ?
Once you have done that, higher-level functions - like creating a filesystem - are oblivious to the underlying interface.
See: http://elm-chan.org/fsw/ff/doc/appnote.html#port
HDaji.1
@Andrew Neil  thanks for your reply.
Maybe this link, http://elm-chan.org/docs/mmc/mmc_e.html, is more relevant.
