2016-06-17 3:00 PM
I am using both I2Cs in my board. Also, using DMA for non-blocking.
HAL_I2C_Master_Transmit_DMA generates interrupt for completion (also for reception and error.HAL only allows for one ''weak'' callback for both.Is there away to name my callback functions (complete/error ...) for each I2C in order to separate logic for each I2C? Thanks. #stm32f4xx-i2c-hal_callbacks2016-06-28 6:24 AM
Hi alsaleem.ahmad,
You may add a check on I2C instance in the CallBack function then implement what you need depending on the instance.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
