FatFS on STM32u5: f_mount freezes
AbhayG1
Split from FATFS for STM32u575 - this is a different issue.
helloo, i did the same exact thing and everything compiled properly, but after running it, the code freezes when the f_mount() function is encountered. Did you find a solution to your problem ??
Andrew Neil
Welcome to the forum.
Please see: How to write your question to maximize your chances to find a solution for best results.
What debugging have you done to find where & why, exactly, it is hanging?
Have you tried stepping into that function ?
