2021-05-20 4:50 AM
The issue am facing is . I have created 4 maximum connection for 1 port at particular 1 ip. When i open port of same port number and same IP on terminal the data travel should travel to both the ports. But it comes on only single port.
tcp_write(PersonalTpcb,"1",, 1);
tcp_write send data to terminal of same port alternatively.
2021-07-08 7:40 AM
Hello @Divyanshu ,
Sorry, but your issue is not very clear to me.
Could you please provide more details about your problem, how to reproduce it and the firmware package used ?
Thanks in advance.
Walid.
