Doxygen bug in usb_device.c.
MSipo
Senior II
Getting some doxygen warnings:
usb_device.c:94: warning: unbalanced grouping commands
usb_device.c:98: warning: unbalanced grouping commands
I think the file is missing a couple of @defgroup or @addtogroup.
/* USER CODE BEGIN Header */
  * @file           : usb_device.c
  * @version        : v2.0_Cube
  * @brief          : This file implements the USB Device
  * @attention
  * <h2><center>&copy; Copyright (c) 2020 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under Ultimate Liberty license
  * SLA0044, the "License"; You may not use this file except in compliance with
  * the License. You may obtain a copy of the License at:
  *                             www.st.com/SLA0044
/* USER CODE END Header */
#include "usb_device.h"
#include "usbd_core.h"
#include "usbd_desc.h"
#include "usbd_cdc.h"
#include "usbd_cdc_if.h"
/* USER CODE END Includes */
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USB Device Core handle declaration. */
USBD_HandleTypeDef hUsbDeviceFS;
 * -- Insert your variables declaration here --
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
 * -- Insert your external function declaration here --
/* USER CODE BEGIN 1 */
/* USER CODE END 1 */
  * Init USB device Library, add supported class and start the library
  * @retval None
void MX_USB_DEVICE_Init(void)
  /* USER CODE BEGIN USB_DEVICE_Init_PreTreatment */
  /* USER CODE END USB_DEVICE_Init_PreTreatment */
  /* Init Device Library, add supported class and start the library. */
  if (USBD_Init(&hUsbDeviceFS, &FS_Desc, DEVICE_FS) != USBD_OK)
    Error_Handler();
  if (USBD_RegisterClass(&hUsbDeviceFS, &USBD_CDC) != USBD_OK)
    Error_Handler();
  if (USBD_CDC_RegisterInterface(&hUsbDeviceFS, &USBD_Interface_fops_FS) != USBD_OK)
    Error_Handler();
  if (USBD_Start(&hUsbDeviceFS) != USBD_OK)
    Error_Handler();
  /* USER CODE BEGIN USB_DEVICE_Init_PostTreatment */
  /* USER CODE END USB_DEVICE_Init_PostTreatment */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
0 REPLIES 0
