2024-05-31 02:32 AM - last edited on 2024-05-31 02:39 AM by STTwo-32
Hello @STTwo-32
I would like to use FreeRTOS with TZ projects. In the case of X-CUBE-FREERTOS 1.1.0, I can select X-CUBE-FREERTOS with both Secure and Non-Secure. But, in the case of X-CUBE-FREERTOS 1.2.0, I cannot select X-CUBE-FREERTOS with both. Could you check this?
Best regards,
K.O.
2024-05-31 09:55 AM
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
2024-05-31 11:12 AM
I have same problem with FreeRTOS.
