Does anyone know software which can convert my audio .wav file to C code? I'm trying to use i2s on my stm32 board but the output i am getting is gibberish audio. Currently I have used Wav to code software but i'm not satisfied with it.
MGogr.1
3 REPLIES 3
C code, or an array of bytes/words?
Should be a couple of minutes coding with STDIO file functions on your host PC​
An array of bytes.
i want to use i2s function which requires array of music file. How that can be done STDIO file? I didnt understood.
When you dont understand coding for PC open file ... read ... write .. close
try What is Bin2c (segger.com) or other utils
